Dynamically driven.
Designed for dynamic headphones, the Reference Headphone Amp is a fully balanced amplifier. Boasting 139dB of dynamic range, the amp works in tandem with the Reference and Select DAC, allowing the music to come to life in vibrant and unforgettable new ways.
CNC billet chassis.
Starting with a 65lb plate of raw aluminum, material is machined in our own in-house CNC shop. After more than four hours of machining, 60% of the aluminum is removed, resulting in a significantly lighter, more contoured product with the best anodized finishes on the market.
4-Pin XLR
Each amplifier is equipped with three 4-pin XLR outputs, designed for a shared listening experience.
Fully equipped.
A rear-facing headphone jack allows for a cleaner system aesthetic—there aren’t any dangling cables interfering with a cleanly assembled system. The noise floor is reduced with an isolated transformer and grounding scheme. 12 Volt triggers allow remote control over the system power.
Analog bypass.
If you’re sharing the headphones with a two-channel system, use our internal bypass we’ve installed directly into the amp. Simply turn off the unit for the signal to be sent to your other system.
Trade in program.
While we’re committed to long lasting products that hold their value, we realize audio systems are always evolving. That’s why we’re thrilled to offer up to 100% trade-in value for existing MSB products when upgrading to a higher performing series. If you currently have an MSB DAC or amplifier that you love–but are looking to experience more from your system–please reach out to your local dealer. We’ll build a personalized offer for your existing MSB products that count towards a new DAC or amplifier. Let us do the work of refurbishing and finding your current electronics a new home–they’ll continue to be enjoyed for years to come.
People are talking.
Since opening our doors in 1989, we’ve been driven by one goal: to craft an unrivaled listening experience for music lovers across the globe. In that time, we’ve pushed the industry forward with each product we’ve built, redefining what’s possible. But don’t take our word for it. See what the reviews are saying.
The best of the best.
At MSB, we believe excellence is a promise worth keeping. We’re honored to be recognized by the industry for bringing you the most lifelike sound we can. Check out the awards + accolades.
Anodized finishes.
The 12V Trigger Adapter
The 12V trigger adapter provides a multitude of ways for connecting your MSB product with other 12V trigger systems.
