Features | Support
The S500 Stereo Amplifier – Support
User Manuals:
- User Manual
- Packaging Guide
- Technical Specifications
System Setup:
Technical Specifications:
The S500 Stereo Amplifier |
| Static Power Consumption | 270 Watts |
| Operating Voltage Range | 120/240V (Auto switching) 100V (Fixed) |
| Fuse | 1/4"x1-1/4" 15A 250V Slow Blow |
| Input | 2x XLR Input |
| Output | 1x Binding post set per channel |
| Controls | Gain switch Input Impedance Switch On/Off Button Standby button Display Dimmer 12V Mode Switch 2x MSB 12V trigger port |
| Continuous Power Output (8Ω) < 1% distortion | 500 W |
| Continuous Power Output (4Ω) < 1% distortion | 900 W |
| Frequency Response (20 to 20kHz) | ±0.025dB |
| Signal to Noise (20 to 22kHz) | >136dB (>140dBA) |
| Equivalent Input Noise (22kHz BW) | 0.5μV |
| Crosstalk @ 2kHz | <-110dB |
| Low Gain (75Ω source impedance) | 16.2dB |
| Medium Gain (75Ω source impedance) | 22.2dB |
| High Gain (75Ω source impedance) | 28.2dB |
| Input Impedance (User Selectable) | 75Ω / 300Ω / 1.2kΩ |
| Output Impedance (20 to 20kHz) | 0.07Ω |
| Input/Gain Stage | - Class-A - Double balanced - Impedance matched - Fully discrete - Independent power and transformer |
| Output Stage | - Class-AB - Balanced - High bias - Current gain only |
| Width: | 15 in (381 mm) |
| Depth: | 23.25 in (590 mm) |
| Height: | 10.5 in (267 mm) Without Feet 12.125 in (308 mm) With Feet |
| Weight: | 135 lbs (61.25 kg) |
| Product Feet: | M6X1 Thread 3 or 4 Foot Configuration |
| Width: | 23 in (585 mm) |
| Depth: | 35 in (889 mm) |
| Height: | 21 in (534 mm) |
| Weight: | 194 lbs (88 kg) |
IEC C19 Power Cord | |
The S500 Stereo Amplifier Foot Dimensions
