The Electrostatic Headphone Amplifier - Support
*Discontinued Product. Some upgrades and accessories may still be available*
User Manuals:
- User Manual
- Technical Specifications
System Setup:
The Electrostatic Headphone Amplifier - Features
Electrostatic headphones.
With the great variety of headphone choices, it is only possible to achieve the best performance with a single headset in mind. You can not use the universal headphone amp concept with the Select level of performance. That is why we have built a dedicated Stax* headphone amp to be paired the the Select DAC.
*Stax Limited will not be liable for any damage to the headphones caused by the MSB Select Headphone Amplifier.
Integrated system.
The Select Headphone Amplifier has been designed to take advantage of the powerful DAC outputs. This allows it to achieve a level of headphone playback never heard.
Analog bypass.
If you are sharing the headphones with a two channel system, use an internal bypass in the amp. Simply turn off the unit for the signal to be sent to your other system.
CNC billet chassis.
Starting with a 65lb plate of raw aluminum, material is machined in our own in-house CNC shop. After more than four hours of machining, 60% of the aluminum is removed, resulting in a significantly lighter, more contoured product with the best anodized finishes on the market.
The 12V Trigger Adapter
The 12V trigger adapter provides a multitude of ways for connecting your MSB product with other 12V trigger systems.
