After years of headphone amp design experience, listener feedback and numerous prototypes, we’re proud to introduce the Premier Headphone Amplifier. Guided by our design principles, we achieved a perfect balance of quality, functionality and beauty. When paired with our world-class Premier or Discrete DAC, you can experience the finest digital audio on a widely supported variety of dynamic headphones.
Dynamic Performance.
High-resolution audio sources shine with our fully balanced architecture, ultra-low noise floor and impedance matched circuit topology. The Premier Headphone amplifier maintains this balanced topology from the input’s origin all the way to its 4-pin XLR output. If single-ended headphones are being used, it automatically reconfigures itself when the ¼” jack is inserted. Experience balanced or single-ended headphones without compromising either one’s performance.
Your headphones. Your system. Your choice.
The rugged class A amplifier utilizes a unique Zero Negative feedback, high-voltage, current mode circuit that is load independent. The amplifier automatically adjusts to the load that it’s driving without affecting its stability or sound quality. The amp supports headphones that are spec’d from Mega-Ohms down to a fraction of an ohm. From power hungry planar magnetics to efficient IEM’s, nearly all dynamic headphones are optimally driven. Boasting 134dBA of dynamic range and a high-power class A design, the Premier Headphone Amp easily performs the softest background ambiance to the most explosive crescendos.
CNC billet chassis.
Machined in-house, the sleek unibody chassis allowed us to evenly dissipate heat with an astounding 12,000 in2 (7.75 m2) of heatsink area. With powerful class A amplification, advanced thermal design becomes critical for component longevity and long-term performance.
Power and Shielding.
The Premier Headphone Amp is powered by a custom wound, ultra low-noise, and shielded transformer. To mitigate the effects of residual stray magnetic fields, it’s housed in a CNC machined pocket lined with additional mu-metal shielding. The custom made Lundahl output transformers are also installed in individual machined cavities and located as far from any sensitive input circuitry as possible. Everything is measured, shielded and optimized for this compact yet functional layout.
Fully equipped.
Daily headphone use needs to be easy and comforting to use. With the included 12-Volt trigger connected to your Premier Powerbase, the Headphone amp will automatically turn on and off with your system. Forward facing jacks make it easy to plug in and switch headphones, making it simpler to dive into your music.
Analog bypass.
After a long session of headphone listening, simply switch to the included Bypass Mode to send your music to your desk monitors or home system to share music with friends and family.
Anodized finishes.
Trade in program.
While we’re committed to long lasting products that hold their value, we realize audio systems are always evolving. That’s why we’re thrilled to offer up to 100% trade-in value for existing MSB products when upgrading to a higher performing series. If you currently have an MSB DAC or amplifier that you love–but are looking to experience more from your system–please reach out to your local dealer. We’ll build a personalized offer for your existing MSB products that count towards a new DAC or amplifier. Let us do the work of refurbishing and finding your current electronics a new home–they’ll continue to be enjoyed for years to come.
People are talking.
Since opening our doors in 1989, we’ve been driven by one goal: to craft an unrivaled listening experience for music lovers across the globe. In that time, we’ve pushed the industry forward with each product we’ve built, redefining what’s possible. But don’t take our word for it. See what the reviews are saying.
The best of the best.
At MSB, we believe excellence is a promise worth keeping. We’re honored to be recognized by the industry for bringing you the most lifelike sound we can. Check out the awards + accolades.
The 12V Trigger Adapter
The 12V trigger adapter provides a multitude of ways for connecting your MSB product with other 12V trigger systems.
