The Premier Headphone Amplifier – Support
System Setup:
Technical Specifications:
The Premier Headphone Amplifier |
Supported Formats | Analog Only |
XLR Analog Inputs | Optimized for 75Ω or 150Ω Balanced Source |
XLR Analog Outputs | Direct connection to input when enabled or unit powered off. When listening to headphones, output is muted with 75Ω output impedance |
Headphone Output Impedance | 40Ω |
Dynamic Range 20Hz-20kHz (Max Power at 45Ω) | >125dB >134dBA |
Frequency Response | 20Hz-20kHz ±0.3dB |
Common Mode Rejection Ratio | > 82dB CMRR @ 60Hz > 82dB CMRR @ 1kHz > 80dB CMRR @ 20kHz |
Crosstalk | <-110dB Crosstalk @ 1kHz <-90dB Crosstalk @ 20kHz |
Max Power @ 1% THD+N | 8Ω @ 4.5Vrms (2.53W) |
16Ω @ 7.5Vrms (3.51W) | |
32Ω @ 11.4Vrms (4.06W) | |
45Ω @ 13.2Vrms (3.87W) | |
150Ω @ 13.8Vrms (1.27W) | |
Headphone Output Connectors | 1x 4 Pin XLR 2x 1/4" Stereo Jack (Single-ended) |
Display | Power LED |
Controls | Rear panel power switch Front panel passthrough/Headphone toggle switch 1x MSB 12V Trigger |
Power Consumption | 82 Watts |
AC Voltage | 100V (Fixed) 120/240V (User switch on bottom of unit) |
Input/Gain Stage | - Class A - Double balanced - Impedance matched - Fully discrete |
Output Stage | - Class A - Balanced or Single-ended* *Only in single-ended mode when 1/4" jack is used |
Width: | 17 in (432 mm) |
Depth: | 12 in (305 mm) |
Chassis Height (Without Feet): | 2.45 in (62 mm) |
Stack height: | 3.05 in (77 mm) |
Weight: | 31 lbs (14 kg) |
Product Feet: | The Viton Foot (M6X1 Thread) |
Width: | 22 in (558.8 mm) |
Depth: | 18 in (457.2 mm) |
Height: | 7 in (177.8 mm) |
Weight: | 40 lbs (18.2 kg) |
Grounding cable |
