Bit Perfect Testing
Perhaps one of the most useful features of MSB DACs is the bit-perfect test. A series of files can be downloaded here. They are .wav test files that when played, will be identified by the MSB DAC and checked, and will be reported on the display if they are bit perfect. The message will stay on for a few seconds. If there is a problem with the test, the file will play and a loud burst of static like sound will be heard but the display will not indicate any change.
Warning! These files contain 0 db content. Turn your volume down before playing.
Bit Perfect Standard File Downloads
- 16 bit x 44.1 kHz sample rate file (CD standard).
- 24 bit x 44.1 kHz sample rate file.
- 16 bit x 48 kHz sample rate file.
- 24 bit x 48 kHz sample rate file.
- 16 bit x 88.2 kHz sample rate file.
- 24 bit x 88.2 kHz sample rate file.
- 16 bit x 96 kHz sample rate file.
- 24 bit x 96 kHz sample rate file.
- 16 bit x 176.4 kHz sample rate file Rev2.
- 24 bit x 176.4 kHz sample rate file.
- 16 bit x 192 kHz sample rate file.
- 24 bit x 192 kHz sample rate file.
- 16 bit x 352.8 kHz sample rate file.
- 24 bit x 352.8 kHz sample rate file.
- 16 bit x 384 kHz sample rate file.
- 24 bit x 384 kHz sample rate file.
